Recovering data with broken system
Windows 8.1 won't boot on this device. I have some important files to recover from it. Bootable usb with linux doesn't help. Is there a way to get them back?
Это хороший вопрос?
Это хороший вопрос?
You can try using an external USB adapter for the drive and then connect it to a working computer to try to copy your data.
Был ли этот ответ полезен?
does it have hdd though?
HDD or SSD? both should work fine with a hard drive docking station. You can find them on amazon I'm sure, or just open up your desktop and connect with sata.
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 12
За всё время: 429
6 Комментариев
Do you have a working desktop PC? So you could test the disk.
из ULEES
i have but im not sure if it has internal hdd
из Tomasz Kowalski
How did it break? did you drop it? spill something on it?
из Aiden
i installed updates and the system crashed
из Tomasz Kowalski
Problem fixed: i booted the windows 8.1 usb drive, then launched cmd. Using it I managed to move all the files to the usb. However switching between the drives doesn't work without "cd /d c:\".
из Tomasz Kowalski
Показать 1 больше комментариев
