The Lenovo ThinkPad X1 Carbon 2nd Gen is the second generation of Lenovo's X1 series ultrabook.
No backlight with blown fuse under lvds connector
Good day
i have thinkpad x1 gen2 with black screen, i can see faint image with torch and external display works fine, i disassemble it and saw a blown fuse under lvds connector on main-board, i replaced it with same fuse and it blown right away after single test, there is an 8pin IC next to the fuse which i believe to be for black-light or something which is not good i think, i want to replace it but i can not read its number so i can order it, will someone help me identify this IC,
https://ibb.co/bGjPe6
https://ibb.co/mz0msR
Thanks
Это хороший вопрос?
Счет 1
1 Комментарий
I found Fuse 1 blown replaced it .
the Fuse is on the opposite side of the motherboard where the screen connector to motherboard is , it is covered in sticky protective plastic.
unfortunately to me the laptop stopped powering on something else has happened to it that I could not fined yet.
Power starts green light flashes then the fan starts then power off follows
из
Добавить комментарий
1 ответ
Выбранное решение
On my X1 carbon gen3 it says F:2B on that IC.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thanks alot Jarlvik, Yes it is F:2B but just cannot find it anywhere on internet. Greets
из
Добавьте свой ответ
Khizar Hayat буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 16
За всё время: 3,157
