Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2265вопросов Показать все
iPhone 7 BB CPU itself shorted
Has anyone had any Iphone 7 BB CPU shorted yet? I have done several 4013 and -1 repairs on these and recently took in 2 phones from a shop in Florida where I had a short on BBPMU_TO_PMU_AMUX1 and PP_1V0_LDO9 on one phone and just PP_1V0_LDO9 on the other. After removing the BB CPU the shorts went away on both, so I reballed and placed it back and shorts came back. Thinking I just made a mistake, I reballed both again and shorts came back a second time. I then checked those lines on the BB CPU and sure enough they are shorted within the BB CPU itself.
1. Has anyone else experienced this ...
2. I have NAND Programmer(s) but nothing for BB CPU... Is it even possible? Or does anyone have a programmer to reprogram new IC's?
Это хороший вопрос?
Оценка 1
1 Комментарий
Now i have this problem... I re assembled phone
из
Добавить комментарий
3 Ответов
Выбранное решение
You might want to reach out to specialized vendors like VIPProgrammer or UnionRepair. They may be able to program a replacement BB if you give them the proper metadata. I have a similar issue with an iPhone 6 where I may need to replace the BB.
I also seem to recall a similar post on the FB group (MicroSoldering & Board Level Diagnosis), you may want to check it out.
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
@refectio I just received an answer from Vipprogrammer.com. I added a screen shot in my question...I was told that there is no programmer :(
из
Darn...
из
I have same problem here.. I re assembled phone :- )
из
Yes, we've seen three of these now. There are two different versions of the iphone 7 logic boards. It seems to be only happening on one version. The short is within the BB CPU chip itself. No way of fixing it that I know of. Perhaps data recovery, but I'm not certain at this point.
Оценка 1
I have seen lot of this case. Especially it shorted on BBPMU_TO_PMU_AMUX1 , PP_1V0_SMPS5, PP_1V0_LDO9. Theres no way to fix if u not found any caps shorted.
Оценка 0
Добавьте свой ответ
The Microsoldering Shop будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 3,246
