The following information is intended to help service the Nerf N-Strike Elite Strongarm . The Strongarm was released in 2013 by Hasbro under their Nerf brand.
18вопросов Показать все
Why won’t my barrel turn after I shoot
I had my strong arm for a while and I can’t figure out why when I shoot it the barrel won’t turn and also it creates a loud sound when I shoot it. Very rarely would the barrel turn when I shoot, what should I do?
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
It could be that the gears are slipping or worn out
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Should I open it check for a problem?
из
Ter ar please u can send it to that can fix it but unles u hav the rite gier u won’t be abol to fix it
из
Mine was doing this, and it turns out that the gears were fine, but a screw post that holds the gear assembly together had split such that the assembly was slipping.
Attempting a repair with epoxy, but expect to have to find parts somewhere, or build a new mechanism.
Оценка 0
Добавьте свой ответ
Christine Berry будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 14
За всё время: 756
