The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
159вопросов Показать все
Will an Xbox One X fit a CPU waterblock?
I want to fit a CPU waterblock for a PC onto the xbox one x motherboard to cool the processor. I need to know how far apart the holes are that I've marked in the attached picture to see if a waterblock is compatible.
https://imgur.com/a/UTW8U
Also, will passive heatsinks be adequate for the memory modules around the processor?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
You will need a block that covers the same area that the original vapor chamber does unless you find a new radical way to cool the other chips. Mini heatsink on each chip will not be enough. Kid next door did it and killed his system.
Был ли этот ответ полезен?
Оценка 0
What if oyou got a big pice of copper that get alle the chips like the original and then got a big waterblock on that? .. maby ?
Оценка 0
Добавьте свой ответ
Myles будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 1,822
