The HP LaserJet CM1415fnw is a multifunction color printer produced by Hewlett Packard.
19вопросов Показать все
Always posting Misprint mess after the first page, then Cleaning mess
When I print it will stop after the second page and say “Misprint” then when I select continue it will print the last page that it printed and the next page.
It will then say Cleaning and then it will say misprint again and print the last page and the next page and so on and so on;
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Have you replaced the drum and toner?
You may need to give the printer a good clean.
Был ли этот ответ полезен?
Оценка 1
5 Комментариев:
I have the same problem, cleaned it with compressed air, changed the cartridges, but there doesnt seem to be a changeable drum
из
All Laser printers use a drum.
Do you have a Jet printer which uses liquid color cartridges?
из
Nope, it is the cm1415. There is no mention of a drum even in the servicemanual
из
The drum is part of each of the color cartridges.
Check the paper feed rollers. If you used a refilled cartridge it may be bad.
из
I have used original cartridges, imitation ones and originals at the moment. Unfortunately I tried to clean the pickup roller yesterday... With silicone spray..., yes not very smart haha, so I ordered a new set of rollers, including a transfer roller. Hope that will do the trick
из
I think it might be an online anomaly, does the indicator light blink?
Оценка 0
Try replacing or cleaning the pickup roller. There is a YouTube video that explains the procedure. I took mine out and cleaned it with a rough sponge and dish soap. Works great now.
Replace or Clean Pickup Roller on HP Pro CM1415fnw
Оценка 0
Добавьте свой ответ
jen cokoa будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 7
За последние 30 дней: 22
За всё время: 1,613
