Main power switch burning out repeatedly
Just had to replace the 4th main switch on my S-24
( 2004 model Rancilio S24 Espresso machine)
switches arc internally and fail every ~6 mos
keeps overheating and melting switch, internal contacts scorched and arcing
even with new switch
Replaced terminal block and spade contacts after it melted the switch terminal block
(a standard part available only by the thousand, apparently)
Any one have any tips on explaining this ?
is it putting too many amps thru switch?
(replaced with OEM 's)
Needing a capacitor or relay?
machine otherwise working fine.
No discussions online (well, one without answer on an Epoca)
Это хороший вопрос?
I have this same problem. Was told by Rancilio that it was likely incoming power quality. Likely too low voltage or amperage to unit. Suggested testing power at source and possibly providing dedicated circuit.
из John Luna
