New screen on 3G but now Apple logo stuck + moving circle
I replaced a screen on a 3g the apple logo is stuck on with revolving circle constantly moving tried hard reboot and via computor still the same even tried replaceing everything exept the logic board still the same, does anyone think its a logic board problem Thanks Sorry did not replace the battery should i give that a try ???? please help
Это хороший вопрос?
5 Комментариев
was the screen working before the change? or couldn't you tell? by screen do you mean lcd or digitiser?
any drop/water damage?
из pollytintop
Do you get an error when restoring via itunes?
Possibly use irecovery to change the env to auto-boot true?
из repairthat
Hi Everyone, Thank you very much for help but found the problem I had replaced the mid frame including the digitizer so I replaced just a Dig onto the old mid frame hey presto its working fine can only presume the mid frame had someting to do with it Happy now Many thanks
из Kevin
did you try to restore via itunes.
i think is software problem.. just try first the basic troubleshooting... software first...
question.- what did you do last time before its happen?
из mix
take a look at kevins comments about this... he has sorted the problem out. It wasn't software
из pollytintop
