Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Home Button Nowhere to connect to
So my Moms iPhone 6 had the problem that the Home Button sometimes didnt register when being pressed to finally to work anymore.
I ordered a new Home Button off Amazon and tried to replace it today, when i wanted to disconnect the old Home button from the flex cable i quickly realized that there was nowhere to connect the new one, i thought that i may ripped off the connector but that was also not the case.
Pictures : https://imgur.com/a/Ex6oz
Would i now need to also order a new Home Button Flex cable and replace that ?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Its ripped.. the connectors on the flex are probably stuck in your mothers homebutton. You’ll need a new backplate.
iPhone 6 LCD Shield Plate with Sticker and Home Cable
iPhone 6 LCD Shield Plate with Sticker and Home Cable Изображение
Продукт
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
okay thanks for your help, is it also possible to just buy the flex cable and go with this tutorial : iPhone 6 Home Button Cable Replacement
or does the Sticker not stick as good anymore after opening it up ?
из
You could just order the flex cable, but I personally only orders the complete thing.
из
Добавьте свой ответ
KekoMaster Atmisbir 2 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 61
