A general-purpose audio device that transmits low audio frequencies to your ears.
22вопросов Показать все
What size alternator and batteries do I need to run 2 bamf1.5000D amps
I have 4 15" subwoofers powered by 2 bamf1.5000D amplifiers. I'm trying to figure out what size alternator I need and what size/ how many/and kind of battery/batteries I'll need? I also have my head unit, component speakers and the rest of the cars electrical system to worry about as well so needless to say I'm lost! Any info will help thank you.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
RMS Power rating of your amp/Voltage and no more than 80% efficient so add 20% to the total amperage calculated before. Calculations for your amp (rated at 1100 Watts per channel @4ohms) would look like this:
1100W/12V=92A
20% of 92A= 18Amp
Total 110Amp. Now that is per amplifier. You do need an alternator that can supply this. Since you did not tell us what make and model your vehicle is, we do not know what your stock alternator supplies. I'd go with no less than 270A alternator.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Do you have any recommendations on where to get one?
из
Kyle Still what make and model is your vehicle?
из
Добавьте свой ответ
Kyle Still будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 1,713
