Выпущенный 16 сентября 2016 года смартфон нарекли iPhone 7 Plus. Вышло несколько моделей нового устройства: A1661, A1784, и A1785, а также можно было выбрать между версиями на 32, 128 и 256 Гб встроенного накопителя. На выбор можно было приобрести золотой, розовое золото, серебристый, Jet Black и (PRODUCT) Red оттенки корпусов.
1364вопросов Показать все
Phone won’t boot
Help, my phone won’t boot, it just stays stuck at the apple logo, phone will restore with no issues and after it just stays at the logo, any suggestions? I can always restore but it still stays at the logo. Before I restored it I had it plugged in my pc and it was still on apple logo but I can access photos through my pc so I don’t know why it won’t boot all the way! Help please!
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
First I would start with a new battery. While you have it open check for any water damage. Next I would have the logic board tested. Definitely back up everything if you can
Update (02/04/2018)
What about the connectors on the logic. If you get something to magnify them so you can see better do they look okay. It can get very frustrating some times but what i would do is buy another one from a online app like (Craigs list) or (offer up) that either is locked or has a broken screen so it's cheap but you know it still boots fine. Just make sure you check the IMEI online or call the carrier with the info so you know it's not stolen. Then I would start swapping parts one by one.
I have a feeling though that if you have swapped batteries multiple times and tried to restore it that your have some kind of a software defect or something with that logic board has been damaged.
What was going on with it when this first stared. Did it just happen one day or were you updating it and the battery died maybe?
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
No water damage, changed complete screen battery housing everything twice with oem parts and rep parts. No dice though
из
Добавьте свой ответ
An Vu будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 99
