What does the star in the top right corner of the notification bar mea
What does the star that's in the top right corner of the notification bar mean and how do I get it off
Это хороший вопрос?
Это хороший вопрос?
The 'star' is shown due to a priority setting in your notifications set up. It could've been 'set' by accident and isn't usually a big deal in terms of operation.
However, to remove, you'll have to change your notifications priority in your device Settings.
For the classification, navigate from the home screen of your device:
Menu --> Settings --> Sound & Notifications --> interruptions
To turn interrupt mode off quickly, you might be able to press once on the volume button and then select from
- None
- Priority
- All
Select the entry "All". Finished!
The star icon is now hidden and the interrupt mode disabled.
Был ли этот ответ полезен?
in settings, there is no option called interruptions in my fire tablet.
yes there is not
There's no interruptions option on my tablet either
Menu --> Settings --> Sound & Notification --> When Device is Locked
Then select from
- Show all notification content
- Hide sensitive notification content
- Don't show notifications
Select the entry "Show all notification content". Finished!
The star icon is now hidden. (Maybe not, my device is from 2017 and even this didn't help. If its a glitch then it should work on newer devices.)
In the middle of my star is a T what does this mean?
Also, if you have used your Fire with a Bluetooth device with a Mute button, connect it and hit the Mute button several times. You should see the icon appear and disappear as the DND mode changes.
Found that to be the problem with mine. Had it connected to a Logitech Folio and had accidentally muted the media sounds on the kindle and had not noticed before disconnecting the kindle via Bluetooth... Thanks..
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 70
За всё время: 13,706
