Car tjrns over good but wont run
2003 chwvy cavalier got home from work and parked it .next morning wouldnt start car was running good when i shut it off. The car has spark. And has 55psi for gas to the rail . i already replaced the crank sensor the one behind the starter . tried spraying starter fluid in the intake bit didnt change anything all fuses are good everywhere. No check light on .also tried releaning the key amd still nothing i pulled the spark plugs and they where all dry like it wasn't getting gas ? . am i missing something.
Это хороший вопрос?
If it is an auto, check your neutral switch. That might be faulty.
из sm_vulkus
Yea it is auto Would that cause the injectors not to give gas to the motor? Thanks u for resounding
из Robert preston
Yea it is auto Would that cause the injectors not to give gas to the motor? Thanks u for responding . when i put the car in park it will let me crank it but when its in neautral it wont let me do nothing
из Robert preston
