Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer may stop mid-cycle. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
Cause 2
Door Lock Motor and Switch Assembly
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the washer door is not latched shut, the door switch prevents the washer from operating. If the door lock is defective, the washer may stop mid cycle. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, consult your washer’s diagram and use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
Cause 3
Water Inlet Valve
During the rinse cycle, the water inlet valve opens to allow water to enter the wash tub. If the water inlet valve fails, the washer will continue waiting for the water to enter the washer, causing it to stop mid-cycle. To determine if the water inlet valve is defective, use a multimeter to test it for continuity. If the water inlet valve does not have continuity, replace it.
To clean the lint trap:
Step 1
Lift up the lid to your Kenmore washing machine.
Step 2
Twist off the top of the agitator, the bar in the center of the machine that moves the laundry around.
Step 3
Pull out the plastic lint trap. Empty any debris in the trap and throw the debris away. Place the lint trap back into the agitator.
Step 4
Screw the agitator's top back on.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
