NEED HELP! Camera will not turn on!
My battery is fully charged, but it will not turn on. Please help me figure out how to solve this issue!
Это хороший вопрос?
Это хороший вопрос?
First check the battery compartment door. There is a micro switch that turns the camera off when you open it. If the battery cover does not press down on the switch, the camera won't go on. Make sure that the battery compartment door covers the batteries so that the micro switch senses that the cover is closed.
Был ли этот ответ полезен?
I have tried that and it did not work
having the same problem with my canon rebel, did you ever find a solution
I have the same problem. Is there a solution?
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 14
За всё время: 2,144
