My CD doesn't come out anymore
I get an ERROR and the CD doesn't want to come out anymore when I press the reject button.
Это хороший вопрос?
Это хороший вопрос?
Hi @liesl ,
1. With the ignition switched off try pressing both the CD /Radio Power button and the eject button at the same time to see if the causes the CD to come out.
2. If it doesn't come out, try doing the same with the ignition switched to Accessories.
3. Before you do the following find out the security code for the radio as you will need it to get the radio working again
Remove the fuse for the CD player (Radio?) in the fuse block. Leave the fuse out for about a minute then put it back.
4. If the CD doesn't come out when the power is restored then you may have to take the unit out and dismantle it to get it out.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 68
2 Комментариев
Hi @liesl ,
What is the make and model number of the car audio system?
из jayeff
I don't know. It doesn't say.
из Marit
