Display screen not fully operative
I recently replaced the glass screen on my iPad Mini2 per the guide and when I turn it on the display looks like this:
Do I need to replace the LCD now?
Thanks,
Kirk
Это хороший вопрос?
Thanks,
Kirk
Это хороший вопрос?
Yeah most likely. Try reconnecting the lcd ribbon and also making making sure that the connector pins are intact. If that doesn’t fix it then probably you need a new one. I had this problem with my iPad mini 2 as well and i ended up replacing my lcd.
Был ли этот ответ полезен?
Thanks! Replacing the LCD was the answer. I must have damaged it when I was replacing the cracked screen in the first go round.
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 7
За всё время: 60
1 Комментарий
Thanks I will give this a try.
из mediayogi
