GPS Navigator released in November of 2015 identified with part number 010-01533-07. This GPS includes real time maps, driver alerts and directions.
3вопросов Показать все
I need Activation unlock code for my garmin GPS DISa10p3457288 s\n 5F2051840
Please tell me how to get past this part of the setup process. I bought this from the flea market with no knowledge of being a activation code and now I'm stuck with this.
Это хороший вопрос?
Оценка 3
Добавить комментарий
5 Ответов
Выбранное решение
Have you try contacting Garmin? Garmin Support
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
they dont help
из
Sorry Guy, Time for a new unit then.
из
Time for a non GARMIN unit then.
Gonna send mine to Gramin with some Vaseline just in case they need it.
из
Try this:
  1. Plug your unit into the USB port on your computer. A file will pop up that says “Garmin”. Click on that.
  2. On the next list of files that come up, click on “Garmin”.
  3. In the next list of files that come3 up, click on “Garmin Device”. It is a small text file.
  4. About 12 lines down in the text file will be a line that says, “<UNLOCK><CODE>.
  5. I can’t promise that is THE code you need, but it is worth a try.
Оценка 2
1 Комментарий:
Just wondering if that answer did the trick with the activation code ?
из
You have two options, first being to throw it in the trash. Second would be to find out the format the code is, and then attempt to brute force it.
Оценка 1
Your device is a stolen device, so you can't retrieve the code. because that code came along with the purchased receipt from the Wal Mart store. It has nothing to do with the Garmin they can't even request the Wal Mart to Retrieve that code.
Оценка 0
Yeah, gave up on this unit. Paid $150 for it on eBay so expected it to be legit. Learned my lesson, won't buy Garmin again. Thanks!
Оценка 0
Добавьте свой ответ
Justin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 12
За последние 30 дней: 34
За всё время: 15,197
