Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
97вопросов Показать все
iOS 11 - option for lock screen on off when cover closed missing?
As we all know the power button doesn't work without transferring the ic chip by the home button after replacing the screen.
In iOS 10 there was an option in the display settings to disable the screen turning off when the cover was closed and that would solve the lock button issue while you tested the new screen etc.
Where is that option in iOS 11, I can't find it anywhere.
Это хороший вопрос?
Оценка 1
5 Комментариев:
Anyone have an idea?
из
Are you using a real smart cover or a 3rd part smart cover? There was a mention that on the iPad 4, the option as of iOS 11 only appears if it detects the magnets attaching the cover to the iPad.
из
Good idea, thanks. Tried that but no go, the option is still nowhere to be found.
из
Put on assistive touch in general settings. Click on device when installed. Then click on lock screen. Magnetic shutdown does not exist on latest and newest iPad, Shame on apple! Brian
из
I have this problem on my iPhone 7plus the option isn’t there
из
Добавить комментарий
3 Ответов
Put on assistive touch. Click on to device. Then tap lock screen. No other way!
Был ли этот ответ полезен?
Оценка 0
Settings > Display & Brightness > Lock/Unlock > On (Green)
Оценка 0
I have an iPad 4 iOS 10. In Display Brightness the only option I have is Auto-Lock with settings of 15 mins to never. No off on lock setting available
Оценка 0
Добавьте свой ответ
workingshane будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 10
За последние 30 дней: 24
За всё время: 41,643
