The LG Stylo 3 Plus is an Android smartphone released in 2017 by T-Mobile. It features a 5.7-inch HD display, 32 GB of storage, and runs the Android 7 OS.
Help merging 2 incoming calls
Hi I have the lg stylo 3 I'm having trouble with the 3-way calling. When I try to merge the 3rd party the only option I'm given is swap calls. Im not given the merge calls option, help.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
From the phone dialing screen tap the menu (3 dots), and there should be an option "Add Call". Dial that number you want to add, or via contacts.
When the second call is established, there should be a "Merge Call" option.
Был ли этот ответ полезен?
Счет 2
4 Комментариев:
Yes there is a merge option but when I click merge it say cannot merge calls and then it hangs up
из
OK, then its an issue with your phone. See if there is a software update to fix this.
check settings --> About phone --> Software update or
Settings --> software update, depending on the carrier.
If this doesn't resolve it, contact your carrier.
из
Any idea if there is no Add Call button in Dialer app (Phone is LG G6 U plus) Korean set ?
из
Try going into ncall setting and enable your confrence calls
из
Добавьте свой ответ
Tanya Bernal буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 1,940
