The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
Rear Brake light is out and its not the bulb.
Rear Brake light out and both brake a front blinkers work on and off with the light flickering fast when it does work. Help
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
OhhhK. When your indicators flash fast, usually that means that one has blown or has a fault. Or it could be your indicator relay.
If the rear brake light is out and it isn't the bulb, then it can only either be a fuse, relay or wiring. I'd check your fuses first.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Alison McCaulley буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 238
