The current line of iPod touch comprises seven (7) different generations.
How to I fix my disabled iPod Touch?
My iPod got locked and is now disabled. I forgot the password and the home button doesn't work. Is there any way I can get my iPod into DFU mode without using the home button?
Это хороший вопрос?
Оценка 181
40 Комментариев
What does your screen tell you about your device being disabled?
из
it says IPOD DISABLED at the top and has no slide to unlock or password.
из
My ipod got locked and now disabled. I forgot the pass code and unable to open. What shall I do.
из
My I pod is disable and I do not have a computer so can I fix it with the buttons
из
if you reset it does it erase everything on your ipod
из
Показать 35 больше комментариев
Добавить комментарий
Ответов (12)
Выбранное решение
Apple says "If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons." So, in your case since you do not have a working home button, you may have some trouble with that. It looks to me that in order to get it properly reset, fix the home button first. It is really not that difficult and there are plenty of guides on here to help you with that. Once you have your home button fixed you can reset your iPod this way. Now there is a way to erase the password but I am not sure if this would work when you are already disabled. I guess you can always try and hope you have a windows computer :-) anyhow you plug in your iPod. Open My Computer (or Computer for Vista). Click on Folder options and enable to view hidden files. Next go to iPod_control and click on the folder named Device. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked. Remove your iPod and it will be cleared, again not sure if it works for a disabled one. Just thought of something else. Make sure you have your library backed up. Once your ipod is plugged into your computer and it shows up as a drive you might have a try at thisGood Luck
Был ли этот ответ полезен?
Оценка 40
10 Комментариев:
OMG...this was so helpful ...thnx
из
what do you do when the iTunes come up and the plug becuses I have already piuged it in
из
where is iPod_control
из
my i pod touch has a time lock.
из
Ok so my iPod said it is disstabled and to connect to iTunes and my home button is broken but I have this thing on the front of the screen and it still works it has home button control centre voice control fav notificasion centre and lock siren multitasking shake screen shots but will that help with anything
из
Показать 5 больше комментариев
Well, this is how I did it. It may not work the first few times, (as I experinced.) but it will work at some point.
step 1. Hold down power and home button for around 7-10 seconds.
step 2. Once it has turned off release your finger from the power button, while keep a finger on the home button.
step 3. The screen should go blank (black)
step 4. Open iTunes and something should come up. You have to download a software (that's what I had to do) and after the downloading is done, it restores your ipod.
I had alot of trouble making this work but on the like fourth or fifth try it acuallyy worked! And if I didnt make this clear yet, you will probaly have to try several times to get the screen blank. But in the end everythings ok because you got your ipod back!! Like I said, it will take alot of time trying, but it will work. I hope this works for you! Good luck! :) And if this was caused by you forgetting your passcode, I strongly suggest you use a easier code like 7-6-5-4 or 2-4-6-8 or something easy like that just so it doesnt happen agian! Good luck agan!! :)
And please do beware of it deleting everything on there, so really it will be like a brand new ipod. *******IT WILL DELETE EVERYTHING! LEAVING IT AS A NEW IPOD!**********
Оценка 19
8 Комментариев:
This worked amazing! I bought ipod off ebay that had been disabled, held down both home button and power button til screen went black and released power button, all while connected to my computer. ITunes popped up and said ipod in recovery mode and downloaded program to restore it. worked the first TIME!! Thanks :)
из
Perfect! Had an ipod touch 4th 4thGen which had been disabled (lost the pin code). Did as instructed here and got it recovered and now it´s working fine. But remember to hold the home button pressed while you connect it to your computer and start iTunes until it says your iPod is connected. Then follow iTunes instructions.
из
i tried to do that but the itunes thing doesn't come up i mean doesn't say anything bout restoring. :/
из
i already try that but it did not work.
из
This worked for Me "Gabby", Thank you for your wonderful explanation.!! Cheers...
из
Показать 3 больше комментариев
Turn your ipod off im sure you can when the screen is diabled then hold the home key in then plug it into your computer (itunes) this will put your ipod into recovery mode then you must restore it well thats all that will come up. once it has restored you can re-sync it to your itunes.
this also works on pin locked iphones ipod etc etc etc....!
Оценка 7
Go on iTunes and click restore and it will ask you if you want to back up you iPod. Click yes and it will save all your stuff and then when your done restoring it will put you stuff back on there
Оценка 3
2 Комментариев:
Will it Delete all my music ?
из
sure thing Juan
из
There are programs out there that can achieve things such as getting into recovery mode or if your stuck in recovery mode it will kick the device out of it. DFU mode is basically another kind of recovery mode other than the original one already detected by iTunes. DFU bypasses firmware issues, most of them.
A program called Recboot may help you in this occasion.
i have a link too download it but just check Google for future updates on the program.
http://www.mediafire.com/?nn1kzmmwkjg
If this doesn't work then just try to plug your device in and click restore. Make sure you have a backup of your device and simply restore it back to original. Even though i would extremely recommend you get your Home button fix pronto its just one of those things you need too have, but quick tip: if you get your iPod Touch back into original state and you are one of those who (Jailbrakes) their devices i would download through Cydia called Activator. This makes you be able to use functions like your home button would with any other button or even the status bar,ect & ect.
Оценка 2
1 Комментарий:
+ very sound advice.
из
My name is ahmed. if you have any questions ask me. plug your device to the computer. wait a moment and itunes will pop out. Click on the ipods main name. scroll down and you will see the word restore. Click on restore and your ipod will be restoring which means it is restarting. When the restore is finished then unplug your device. you will be using a new ipod.
Оценка 2
2 Комментариев:
Hi im having trouble with my ipod its not letting me put my ipod into recovery mode cause i accidently pulled the cord out while it was in recovery mode it just goes black and thats it
из
What if you don't have a computer?
из
Thank you everyone for the help! It was awesome!
But I think I know how to help you people like me; I changed my password and then couldn't remember it so I went on iTunes and pressed restore, and backed it up, right? But then it didn't work so then I finally realized that you have to press restore, and NOT BACKUP because then it just restores your iPod to the same password. But before you do this you have to import your photos so you don't lose them; how you do this is when you first plug in your iPod it will say import photos, or open file, so you press import photos its pretty straight forward from there.
Hopes this helps!
Оценка 2
1 Комментарий:
check the answer by lukesinnott sinnott
из
press off and home button for about 10 seconds then release off button and plug it into itunes in your computer then click restore if it does not work try again some more several times as i did to fix my ipod
Оценка 0
You need to plug it into the computer with usb cable then go onto itunes and restore it. try this website....
http://www.ask.com/answers/133002401/how...
hope this helped ;)
Оценка 0
Method 1: Fix Disabled/Locked iPhone or iPad using iTunes without Losing Data
If you have synced your iPhone or iPad with iTunes before, it is easy to unlock your device by restoring. To avoid data loss, download and install Yolisoft iPhone Data Recovery on your computer first. It is a professional tool to help you retrieve deleted or lost data from your iDevice directly or from iTunes or iCloud backup.
Method 2: Unlock Disabled/Locked iPhone or iPad by Using iCloud
Provided that you have set up "Find My iPhone" on your iPhone or iPad, you can use iCloud to get back your device.
Go to https://www.icloud.com/#find on your computer or other device.
Sign in with your iCloud Apple ID.
Click "Find My iPhone" and "All Devices" at the top of your browser window.
Choose the iPhone or iPad you want to erase, and click "Erase iPhone/iPad" on the top right.
After the process completed, there is no passcode on your lock screen. Now you can choose to either set up as a new iPhone/ iPad or restore it from the iCloud backup.
Method 3: Unlock Disabled/Locked iPhone, iPad or iPod Touch in Recovery Mode
If you have never backed up your iPhone or iPad and set up Find My iPhone in iCloud or synced your device with iTunes, recovery mode is your last resort to restore your device.
Open iTunes and connect your iOS device with your computer or Mac via an USB cable.
Turn off the iPhone or iPad by holding the Power button to swipe the "slide to power off" to the right.
On an iPhone 6s and earlier, or iPad: press and hold the Power and Home buttons at the same time. On an iPhone 7 or iPhone 7 Plus: press and hold the Power and Volume Down buttons at the same time. Don't let go of the two buttons until you see the recovery mode screen.
A message will pop up which means your device have been in recovery mode. You will be asked to choose Update or Restore. Click "Restore". iTunes will download software for your iPhone or iPad. It might take some time to restore your device.
After the restoring process finished, you will see a white screen with "Hello" in different languages. Then you can reset your device as a new one.
https://goo.gl/HKfiCo
Оценка 0
This sounds worse. If you want to recover your ios system, you need to use third-party software to fix it. Fucosoft IOS System Recovery is a professional software for repairing iOS system, which can solve iOS problems in many common situations. For example, iPhone card in recovery mode, DFU mode, headphone mode, Apple logo, startup loop, rotating circle, iPhone white/black dead screen, iPhone freeze, iPhone recovery or update failure, iPhone cannot be opened, forget lock screen password, etc. you can try it.
Оценка 0
can you help me keli
Оценка 0
Добавьте свой ответ
Brock будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 46
За всё время: 252,895
