Repair guide and support for the Samsung CLX-3175FN, a multifunctional color laser printer that also works as a fax machine and copier.
15вопросов Показать все
Why it says install toner. SCX-4623FW
I replaced the toner with new one, not from samsung. I printed two times only and now I have "Install toner" message. I removed, shaked and reinstall many times without success.
Update (02/25/2018)
Thanks for your reply! Can you be more specific please? What to look for on ebay, or internet (kit, hard reset)? I mean what to write on search? This will help a lot.
Printer is Samsung SCX-4623FW.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
What several of the lovely Laser and Ink Jet Printer companies do is have a chip on the toner cartridge and some type of reader on the printer to ensure that you are using their (new) cartridges. You may need to search ebay and the internet to locate a "kit" that you can use to defeat the system that is used by that particular printer. Look also for a "hard reset" function that might help reset any of the counters that might prevent printing with aftermarket toner cartridges.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
из
Добавьте свой ответ
Ferdinant будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 2,009
