Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624вопросов Показать все
Bootable external drive not detected by startup manager
I have been trying to boot windows through mac 10.11.6 through startup manager since doing it through system preferences brings up the message no bootable drive error, but when I open startup manager it just brings up the laptops and a recovery drive I tried doing the command option p and r twice but still nothing I also tried to connect it once it is up but still nothing. I installed windows on the drive through a virtual machine running windows 10 and than wintousb to install windows 10 pro.
Это хороший вопрос?
Оценка 0
1 Комментарий:
Also when I boot up from my normal boot disk I have to disconnect than reconnect the hard drive so it can show up
из
Добавить комментарий
1 ответ
Follow this guide: Installing Windows 10 on a Mac without Bootcamp
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
didn't help x as a command doesn't exist
из
What are you looking for here: Command?
из
step 5 under "Ensuring that a Hybrid MBR is not used" terminal doesn't recognize the command and doesn't have it listed when doing the "?" command
из
Добавьте свой ответ
Axel Salas будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 655
