Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Why is my screen black?
I was on Facetime and The screen went black, I thought it was nothing big. I tried resetting it but nothing occurred I even went to a shop to see if it was the screen but it wasn't, I don't know what the issue.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
If a repair shop confirmed that the screen was not the issue (did they try another one?), then your issue is on the logic board. I'm a little surprised that the the shop was not able to tell you if your problem is backlight related though as that is a simple test.
Does iTunes recognize your phone? If so, plug your phone into an iTunes enabled computer and shine a bright flashlight on the screen. If you see a dim image, then you have backlight issue. If not, then it could be an LCD driver issue.
If iTunes does not recognize your phone, then it could be a wide range of issues. Ideally, you will need to have this phone looked at by a micro-solderer so that it can be properly diagnosed.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
john valencia будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 73
