The Kia Sorento is a mid-size crossover SUV (mid-size SUV in its first generation) produced since 2002 by the South Korean manufacturer Kia Motors.
35вопросов Показать все
Drain coolant, how catch in pan, is only a plug to remove, will drain
Need to drain coolant, how to catch coolant in a pan, is only a plug to remove, no fitting to attach hose to lead into a pan, will drain all over. ??
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
You probably will need to remove some of the plastic splash guard panel things under the front of the vehicle to drain the radiator effectively. Me I drained mine by running into a wild hog at 70 mph a couple of years ago.... Needless to say the radiator drained instantly, airbags deployed required a tow in. Car was totaled by insurance :(
Был ли этот ответ полезен?
Оценка 0
You remove the 1 piece splash shield, then radiator drains onto cross member and you clean up the mess. No alternative. Needs large catch pan. Messy.
Оценка 0
Добавьте свой ответ
David Mallory будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 68
