The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313вопросов Показать все
Keyboard not working after replacing the top case
Hello.
So I recently replaced my MacBook Air A1466 top case because a few of the keys stopped working after I spilled some water on it.
After replacing the top case none of the keys work now and I have to plug in an external keyboard to use it.
Every other function of the laptop is working perfectly, even the trackpad.
I have attempted to unplug and replug the relevant fittings with no success. Any advice or other solutions that I can attempt?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
The supplier of the uppercase might have shipped you a bad one. I would contact them.
To see if the system see's the keyboard at all go to 'About This Mac' and click on the Systems Report button. Open the Hardware section & Click on the USB section. You may need to slide the split window a bit down so you can see the bus hierarchy. One of the Hub's show Keyboard Hub > Apple Keyboard, do you see it?
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Andrew будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 265
