The Alienware M18x, also identifiable by its model number R2 AM18XR2-7778BK, is a gaming laptop manufactured by Dell in 2011 with an 18.4 inch screen. It has a 12-cell lithium ion, 3 Megapixel resolution, and Microsoft Windows 7 Home Premium 64-bit Edition.
I would like to be able to repaste my cpu.
I have gotten to the point of taking off the key bard but I have not been able to get to the cpu though I see it.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Hey there Henry, If there is screws on the bottom of your laptop, remove them, and keep note to the order they belong in, as well as there may be some hidden screws underneath riser pads or security stickers. I would also recommend unscrewing any screws underneath the keyboard. Once the bottom screws are removed, this should allow for the bottom panel to come off, and allow you to safely use a flat edged tool carefully pry the top of the frame off. Hopefully this will shed some light on getting it open
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Henry Curran будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 179
