Repair guides and troubleshooting information for microwave ovens.
759вопросов Показать все
Why does the turntable not rotate?
Unable to open case because screws are hex with a pin in the center that keeps a tors bit from unscrewing the screw. I would like to replace the motor for the turntable.
Это хороший вопрос?
Оценка -1
1 Комментарий
What is the brand and model number of your microwave please?
из
Добавить комментарий
2 Ответов
Выбранное решение
Here is a [связанный продукт отсутствует или отключен: IF145-044] that will help you crack the case on that sucker. Once inside, most microwave turntable motors are fairly simple to remove. I've heard that people go around scrounging them out of the trash because they're slow RPM motors that take 120v. Perfect for your disco ball or other slow rotating needs.
Был ли этот ответ полезен?
Оценка 7
8 Комментариев:
+ good answer. Disco Ball? ;-)
из
Every home should have one ;-)
из
I have a lava lamp, does that count? ;-)
из
dunno...do you dance round it?
из
only after listening to ABBA and to much Alvin Stardust ;-)
из
Показать 3 больше комментариев
There are some security screws that protect the microwave from opening by everyone. The screwdrivers that open this class of screws are sold on any tool store like harborfreight.com or Enco. They are not difficult to find, but cannot be find everywhere as other screwdrivers can be found.
Оценка 0
Добавьте свой ответ
Edwin Weiss будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 4,531
