Dell Inspiron 15-3531 laptop with an Intel processor and a non-touch display.
My laptop is overheating!
My laptop is overheating. I have been told that I may need a new fan but I don't want to assume that's the only solution. What is something I can do at home before getting the fan replaced by a specialist?
Это хороший вопрос?
Оценка 2
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Hi Karen! The first thing you should do is make sure your laptop is not sitting on a bed or similar surface as this can block the airflow of the fan and cause your laptop to overheat. If your laptop still feels hot on a cool, hard surface like a desk or table, the fan might be either dusty or broken. You can try to clean the fan; however, if you are still dealing with issues, you may need a replacement fan.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Karen Wright будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 280
