S8 новейший флагманский смартфон компании Samsung, представленный на Unpacked 2017 в апреле.
Boot loop on att logo
I just relaced a customers lcd screen replacement for their galaxy s8 att model. No the phone is in a boot loop, it will get to the att logo, freeze there and then restart. It will not let me into recovery mode or into safe mode. I do not know if it had this issue before because the lcd was broken, please help. Thank you!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
This could be caused by a number of things:
- not making a connection with the screen flex
- bad part
- battery went bad
- when screwing the phone back together you could have overtightened the screws on the motherboard, which can cause many issues.
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
Let me know what ends up being your fix, I'm curious to know.
из
None of those suggestions helped sadly. :(
из
I never screwed in the screws so that isn't it either
из
well all I could say is that if you troubleshooted your connection, it might just be a bad part
из
Добавьте свой ответ
cellphonebuyer1 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 237
