Руководства по ремонту и поддержке внешней вспышки Canon Speedlite 430EX II.
Speedlite 430 EX ii wires resoldering
Hi Everyone,
So I was shooting on a tripod this afternoon when I suddenly tripped on said tripod. It fell on the floor with the flash mounted to top of the camera. The top part of the flash detached leaving the base mount stuck in the camera. Only 3 wires out of 5 remained soldered. I had to force-remove the remaining wires in order to be able to detach the mount from the camera. Here's a picture to better illustrate what I mean. Besides that, I might need to work on the lock mechanism which seems a little off as well.
So the big question for now is which wire goes where? if someone has a diagram, that would be great as I couldn't find any online.
Thanks in advance!
eric.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Hi Eric,
Please see attached pictures.
Let me know if you need any others.
Greetings from South Africa.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
eric duong-lamoureux буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 413
