The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
73вопросов Показать все
Why is my blackberry not turning on but charging only?
my blackberry fell into the water and since then it is not powering on but it usually shows its charging anytime I charge it? any way out?
recently i tried plugging it to my laptop and it came on momentarily nd went of again
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
I’m sorry to hear about the issue with your BlackBerry. It seems that water damage might have caused the problem. When electronic devices come into contact with water, it can cause damage to the internal components, leading to malfunctions or complete failure.
In this case, it is possible that the water damage has affected the power circuitry of your BlackBerry, causing it to not turn on properly. Even though it shows that it is charging, the damage may prevent it from fully powering on.
My suggestion would be to immediately stop trying to turn on the device or charge it further, as it may cause more damage. Instead, I recommend taking it to a professional repair service or contacting the BlackBerry customer support for assistance. They will be able to assess the extent of the damage and provide appropriate solutions to repair or replace the device.
Remember, it’s always important to handle electronic devices with care and avoid exposing them to water or any other liquids.
BTW, welcome to read some related articles about electronic chips like Comparison between RP2040, ESP8266, ESP32, STM32: Pinout , LRS-350-24 AC DC Converters: Datasheet, Advantages, Videoand buy any electronic components in Xinshop.
Был ли этот ответ полезен?
Оценка 0
You should definitely go for a professional cleaning asap. If you can see that the phone is charging ( don't try it again until professional cleaning) but it doesn't power on, maybe the power button flex needs repair or replacement. It is also Very likely to have a motherboard issue but when you come with water damage issue, you should go asap to a technician
Оценка 0
Добавьте свой ответ
Taiye Babade будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 10
За всё время: 75
