Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
61вопросов Показать все
1st attempt at charger port repair, do I need to send out to someone e
This is my first time doing board level repair and I'm not sure if I can attach the charger port on after I tinned the pads. Someone please help. Im attaching pictures for any help.
Это хороший вопрос?
Оценка 0
1 Комментарий
@refectio might have good advice here.
из
Добавить комментарий
1 ответ
Выбранное решение
Several pads are partially missing. You'll need to check the continuity between those pads and their connection points to insure you have a complete connection. If everything checks out okay, then you can solder the flex. You'll need to use a lower temperature than normal when you solder a flex otherwise you can damage it.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
Novice question, how do I check continuity...how do I find ground?
из
If you want to ground yourself, you can use the bottom hole on an outlet (NOT THE LINES) or a radiator. something metal basically.
из
Unfortunately, there is no schematic available for the mini 3 in the wild. You can get the boardviews via ZXW (which is highly recommended if you are serious about micro-soldering). That will show you what is connected to what. To check continuity between pads, you don't need to find ground...you just want to see if the the two pads are connected together.
из
Добавьте свой ответ
Yalena Talley будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 59
