Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
1199вопросов Показать все
Touch screen crazy behavior
Hello , I´ve a serious problem with my Iphone X , the tactile interface creates random clicks on display. For example if I manage to open the calculator some numbers are not working and in other moments start to type ramdom numbers 88789383... and do on. I´m not sure if the problem would be fixed replacing the complete display assembly or I need to replace other parts.
Regards, Patricio.
Это хороший вопрос?
Оценка 4
Добавить комментарий
3 Ответов
Выбранное решение
The display is the likely issue here however given that your phone is surely still under warranty, I would suggest you have it replaced by Apple.
If your phone shows any signs of physical damage, they may refuse to to change the screen in which case a reputable third party repair shop can help you out or you can try it yourself.
Был ли этот ответ полезен?
Оценка 5
1 Комментарий:
I'm having. the same problem and asked for a replacement and is doing the same thing, I can only think is that your part is not fully comparable with my phone I'm going to ask for a refund .
из
My phone had become very glitchy. It would type random numbers or change screens on its own or wouldn’t recognize a touch. After calling Apple three times and going to the Apple store twice, they determined I needed a new display. Since it was still under warranty, there was no charge. So far, problems been solved.
Оценка 0
I've got an Iphone X, the screen was going crazy opening random apps, impossible to type, etc. I was ready to smash it. I went into display settings and turned off True Tone-it seems to be fixed!
Оценка 0
1 Комментарий:
Why would of that fixed it?
Your only changing the colour of the screen
из
Добавьте свой ответ
patriciogreco будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 11
За последние 30 дней: 40
За всё время: 66,500
