A Beanie Baby is a stuffed animal, made by Ty Inc. Each toy has an inner "posable lining" and is stuffed with plastic pellets (or "beans") rather than conventional stuffing, giving Beanie Babies a flexible feel.
6вопросов Показать все
How to fix my beanie boos noes
my dog ate my beanie boo's noes and I want to fix it but how?
Это хороший вопрос?
Оценка 4
5 Комментариев
Was it the plastic part only? Or did your dog chew off the whole nose (like the fabric and some stuffing)?
из
mine is the plastic part and i want to fix too i dont even have the piece
из
Does anyone know where to find just the nose part?
из
Maybe u can use black stitch things to so it back
из
@WrathfulSadness mine was the plastic to, i was thinking we stich a black so to fix it
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Hey Casey,
Check out this guide. It has a couple different ones in it, but I think the most helpful for you would be to check the button one. Then, you can sew on a new button to your beany-baby's nose.
Hope this helps,
-Tanner
Был ли этот ответ полезен?
Оценка 3
If it pulled it off, you can always try to sew it back on but if it chewed it up, you could always replace it with a small button or bead!
Оценка 1
I have the same problem this morning my dog which chewing on my kitty OK she fell off the bed so I don’t wanna put a bead a bead button I can’t see her without her cute little pink nose I’m gonna see how much fabric Is left around her nose thenI’m going to try sewing it also liquid stitch which is what my mom is going to have to do
Оценка 1
1 Комментарий:
My dog ate at it but the nose is still on and she ate at the plastic piece
из
There are often Beanies at thrift stores and garage sales. You may be able to find a replacement nose on another Beanie being sold for a small price. The repair is a little fiddly, but someone who sews should be able to make the replacement. Of course, then there will be another Beanie without a nose… But maybe that is what some little bitty button is for.
Оценка 0
You start with a double whisky neat, to reduce jitters. Go through your other, in tact, beanie babies and scavenge for better, in tact, appendages. Take said appendages such as a nose or arm and replace the &&^&@@ up appendage with the newly, in tact, appendage. Finish with another double whisky neat for a job well done, you deserve it!
Оценка 0
Добавьте свой ответ
casey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 23
За всё время: 2,061
