Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
DFU mode timeout during software extraction
I'm trying to restore an iPhone 7 that is stuck on the connect to iTunes, but iTunes says there is an error and it can't connect. I tried putting the phone into DFU mode and it connects just fine so I start the restoration process but the iPhone will only stay in DFU mode for about 1 minute before restarting and messing up the restoration. Anyone know how to fix this? Thanks in advance!
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
The problem is the iOS file is huge, and it takes too long to download, and DFU mode is impatient.
To fix this issue, first download the iOS IPSW from alink here.
Now, open iTunes and put your phone back into DFU mode.
Instead of straight clicking on the "RESTORE" button,
• on a PC, hold SHIFT, and then click "RESTORE", and select the file you downloaded.
• on a MAC, hold OPTION, and then click "RESTORE", and select the file you downloaded.
This will immediately extract and upload iOS to the phone before it leaves DFU mode.
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
I was able to figure it out. I managed to get the phone in regular recovery mode and restore from there. DFU mode now works normally, so I'm not really sure what the issue was before.
из
Nick rose how did you manage to sort it bud,even tho I've downloaded file without itunes,I'm still timing out at the extracting arghhh
из
Just had the same issue, Restore only updating OS not erasing settings e.g. lock code, so tried DFU mode, iTunes timing out of DFU mode every time during update. Went back to try simple Restore one last time and it magically worked, settings and lock code are now gone, not sure why but happy!
из
You can just disconnect the phone and iTunes will continue download the OS. When it’s done, re-connect, re-enter DFU, and do the restore.
Оценка 0
reinstall iTunes, when prompted if you rather: 1 uninstall and reinstall iTunes or 2 repair itunes. Repair itunes then try dfu reset. worked for me
Оценка 0
1 Комментарий:
iTunes is part of the OS and has been replaced with the Finder for purposes of restore in newer systems anyway. It can not be uninstalled.
из
Добавьте свой ответ
Nick Rose будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 16
За последние 30 дней: 52
За всё время: 8,426
