Which Mac do I have?
The serial numbers are rubbed off
How do I figure out which one I have?
Power supply is broken can’t turn it on.
Thanks
Это хороший вопрос?
Thanks
Это хороший вопрос?
Give us the Model Number and everything on the back of the stand.
If your ports are horizontal in a straight line,you have an iMac Early/Mid/Late 2006. Otherwise if they are in a vertical line,you have an iMac G5.
Был ли этот ответ полезен?
Look on the bottom of the stand. That should give you a model number and a EMC number. It also has the serial number.
The serial number should also be there. You can plug that number in at this link for the complete story on your iMac:
He said the SN was rubbed off. The position of the ports should let him know whether it's an iMac G5 or an iMac Early/Mid/Late 2006.
Thx!! I took a pic of the bottom of computer and I zoomed in and I figured out just the serial number. I put it in that link and I have my info! Thank you!
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 210
1 Комментарий
It’s rubbed off I can’t read it
из Az Brian Montee
