The AKASO KingPad A90 is a 9" tablet with a dual core processor. It has 8GB of internal storage, runs Google Android 4.2 Jelly Bean, has a front and back camera, a rear speaker, and support for HDMI output. This device was released October 31, 2013.
6вопросов Показать все
How to replace screen on Prestigio Wize 3147 tablet
I bought a new glass touchscreen, I have unglued the edges of the broken screen using a hot air gun. The old screen is still attached by a ribbon cable at the top right corner, can't get to the fixing, maybe the display can be lifted out to get at the cable attachment? Or maybe get at it from the other side, via the wee door where the 2 sim cards are?? No obvious way to get it apart. Any suggestions? Thanks!! jake williams
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
My friend came up with the answer, after watcing this video,,,,,, https://www.youtube.com/watch?v=ySfbwUG6... ................ it's about a similar tablet.... the back prises off, using thin knife blades and similar levers...... i couldn't even see that there's a join, there's just a slight line in the plastic, but sure enough it came apart, and there's a socket for the ribbon cable with a locking tab that you can lift up with your thumbnail....jw
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
jake williams будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 255
