Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
2690вопросов Показать все
iPhone 6S No Service but SIM can be read and Modem Firmware is visible
I don't think it's a problem with the SIM reader. I tried a working Verizon one and it called fine when I turned on WiFi Calling, but it still showed Searching and then No Service. If it was a baseband IC chip problem, wouldn't the Modem Firmware be unavailable? Earlier today, I turned off Airplane Mode for whatever reason since I always keep it on and the Verizon text actually showed up with about 3 bars and went back down to No Service within a minute; I've never seen it do that before.
Это хороший вопрос?
Оценка 0
3 Комментариев
Has your issue been fixed? I have exactly the same issue. I think only the Antenna and not a IC is broken...
из
nope. i suspected there was an antenna problem too, but there was no way to test. there are ebay services that will fix "no service" for you for ~$50. search "no service 6s". spending that much now, i don't think you would add to the value of your phone any more than $50, but it would make it more likely to sell. so it might make sense to fix it
из
Thank you for your answer! I ordered a new antenna and if it fixed my issue i will report back. :)
из
Добавить комментарий
2 Ответов
Выбранное решение
No service/intermittent service is an internal problem that should be replaced by Apple. There could be a baseband chip issue - you may send the device to a micro soldering establishment.
Был ли этот ответ полезен?
Оценка 1
Apple can fix it if you send it in or take it to a Apple store for repair. If it’s in warranty they’ll fix it for free, if not the price varies.
Оценка 1
Добавьте свой ответ
M J будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 9
За всё время: 2,545
