Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214вопросов Показать все
Small lightning flash across screen then nothing.
So I recently decided to go into Apple logic board repair after spending 3 years as an electronics apprentice for an automotive company and as a bit of practice I decided to have a go at fixing an ipad air 2 that my dad managed to destroy while removing the screen to retrieve a lost SIM card. Basially when you power the screen up there is a small lightning type flash across the screen then no display what so ever.
I've taken the device apart again, tested the inputs and outputs on the LCD socket and and found a couple of things but am not entirely sure if I'm just reading a few things wrong or if they even make a huge difference, so I'll try to be as concise as I can.
First: EDP_HPD_EMI_CONN has what looks to be a missing 7.5kOhm resistor on its output but as far as I know it is not a critical part of the system and should not cause no display(?)
Second: PP11v3_MESA_FILT seemed to have a short to ground. This being a critical BUS line (could be wrong, am in the very early stages of deciphering ipad schematics) I was pretty certain that this was the fault. So certain in fact, that I bought a spare board online for £30 to swap the few components I though to be responsible. However, upon testing the working board I found that it too had a missing PP11v3 line on pin 19 of the LCD connector.
So, the couple of things I would like to know are, first and foremost - am I reading these schematics "correctly" or as correctly as I can? Think Ive got the tracing pretty much down but all the abbreviations (What's PP? What's MESA? etc.) are throwing me and I'm finding it difficult to find answers on what they all mean so would like to know if there are any sources out there that could help?
Also, have any of you come across this lightning flash problem before? Is it even the logic boards or am I dealing with a dodgy screen? And finally, would the screen power up via the logic board using a bench supply with just the LCD, backlight and touchscreen connectors in place or would everything have to be plugged in? Sorry for the long list guys, just for the record I'm not lazy, I would rather figure this kind of thing out myself but am worried I'm sending myself in the complete wrong direction & would love some guidance by you fine people while I'm starting out if at all possible? P.S - all input/output filters seem to be doing what they should but have heard they can look like they work in circuit while actually not, could the filters be to blame?
Cheers!!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
On the EDP_HPD_EMI_CONN line, if R4690 is missing, then it's as if that line doesn't exist. It's critically important for that resistor to be there.
For the PP11v3_MESA_FILT line, that is responsible for the TouchID function of the Home Button. The shouldn't be shorted to ground. If it truly is, then remove FL4742 to see if the short is on the U4770 side or on the connector side. Then remove the associated capacitors first to see if one of those are causing the short. It may also be U4770 but rule out the caps first.
As for the flash, I doubt it has anything to do with the Mesa line. The missing resistor is on the HPD (hot-plug detect) which is required for the display driver to recognize that there is a display.line
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Very helpful thanks! Guess not seeing the word "CRITICAL" attached to the EDP_HDP line threw me. Wouldn't have thought a touch ID panel would put out 11V either, and didn't actually think to try & beep pin 19 to ground, there's no short there after all so am guessing it only comes to life when you either use the touch panel or at least have it attached. I clearly still have a bit of a ways to go before I can call myself competent lol.
из
Добавьте свой ответ
josh_bausor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 145
