Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586вопросов Показать все
Temperatur Improvement by replacing the Thermal Paste Some Values?
You Mentioned that it could be grate to replace the Termal Paste on these Models and use just the needed amount do you have run some tests how big the improvement in better CPU or GPU Temperatures really is on this model ?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
take a look at these.. arctic silver 5 is the generally used paste for these things, the manufacturers claims 3-12 degrees lowering..
http://www.arcticsilver.com/#
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
+ Nice way to answer. I normally use Arctic Silver 5, but everyone has their preference.
из
I used ceramique once but was unimpressed.. Swapped to no5 after a recommendation on here, I'd have to say it was easier to use and I've no complaints with the result on a few xbox 360 RROD. It's not a mac, but I'm sure Mayer uses it, in fact it may have been his recommendation!
из
+ that's 3-12 degrees lower than standard pastes. Yes I use the Arctic Silver. I didn't like the ceramique either.
из
Добавьте свой ответ
Arne Glodde будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 7
За всё время: 2,321
