The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
Rainbow vertical lines when turned on
These lines show up for about 20 min then go away any idea what the problem is
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
May be a loose connection where when warmed up expansion occurs to create better contact.
Был ли этот ответ полезен?
Счет 1
@jmcubean could be an issue with bad caps or bad solder connections. Post some images of your boards with your question so that we can see what you see. Also, if you can post some images of what your panel first displays. Use this guide Adding images to an existing question for that. Most vertical lines originate with failure of the T-con board or the main board.
Счет 1
Добавьте свой ответ
Julianne буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 439
