Electrolux PLD2850RDC2 or Frigidaire PLD2850RDC2 dishwasher. Stainless steel door with plastic tub.
2вопросов Показать все
dishwasher does not heat
replaced the heating element and it still does not heat
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Cause 1
Heating Element
Some dishwashers use a heating element to heat the dishwasher during the drying cycle. If the heating element has failed, the dishwasher won’t dry dishes properly. To determine if the heating element has burned out, use a multimeter to test it for continuity. If the heating element does not have continuity, replace it.
Here's the part for your machine, thanks for providing the model number ;-)
https://www.repairclinic.com/PartDetail/...
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
I have replaced the heating element and it still dos'nt heat
из
Hi @Fritz Mehrer,
Just wondering if the Hi Limit Thermostat may be faulty preventing the heater element from being turned on.
The page tells you how to test it.
Located as part #F29 from this page
из
Добавьте свой ответ
Fritz Mehrer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 1,352
