Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624вопросов Показать все
How do I boot into utilities as my system is locking up
I turn my MacBook Pro on enter the hardware password and it gets to a gray screen with the indication bar full like it needs but it never gets to the desktop, it just sits there and no combination of keys gets it to do any thing. I am able to shut it off with the power switch.
On start up what is the key you are supposed to press to get into utilities to diagnose?
Это хороший вопрос?
Оценка 0
1 Комментарий
Does your system still have its original HDD or did you upgrade it at some point? If you did upgrade it what did you put in another HDD or SSD?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Press and hold "D" key after you power on the mac to load Apple Diagnostics.
Alternatively if you can connect to internet, press and hold "Option" + "D" key at the same time to load Apple Hardware Test.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
novosad будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 31
