short on 5v7 line
@refectio i bought a liquid damaged se the other day and recieved it this morning. on dc its drawing over half an amp which i would think would be enough to show the apple logo. testing for shorts i found that PP5V7_SAGE_AVDDH is short to ground, i removed c4323 and c4005 as they are the areas that looked a bit damaged. so having no image don't even think i have backlight but havent checked that im guessing that chestnut could be the culprit but i dont really want to remove it unless i need to. would you say chestnut or something else
update: removed chestnut and the short is gone
does your se schematics work on blackfish as i get an error with them
Это хороший вопрос?
1 Комментарий
so i reballed chestnut and now getting even less power at max 0.08 amps. removed chestnut again and still the same, on pp_gpu c1100, c2018 and c2017 will draw full amps (2) from dc but the rest of the caps draw less. any ideas @refectio pp_gpu was the only line shorting to ground aswell after chestnut was sorted removed said caps and a coil still short
из daniel
