Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Replacing motherboard in iPhone 6
Hi, I recently screwed up my motherboard on the iPhone 6 I was wondering if I could buy a replacement board on eBay for like 5$ and fix on all the parts ie storage cpu etc. And use that board in exchange?
Thanks for the help.
Это хороший вопрос?
Оценка 1
1 Комментарий
What exactly did you screw up?
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
you can, but you need to buy a tool from Rewa technology to format and register a serial number to your internal storage. they have a video here: https://www.youtube.com/watch?v=v5WDDZqh...
its for a 6s but its the same process.
It is very expensive for the tool and very easy to break things, so it may be better to buy a working motherboard.
Был ли этот ответ полезен?
Оценка 1
Hallo, this board what you find on ebay is blank board.... like dummy.... is only board without all chips etc.... send me the link.... i see too much on aliexpress this board for 4-12dollar... all dummy.
Оценка 1
Can you microsolder? This is a lengthy process. What exactly did you “mess” up on the board? If you need data there are other avenues depending on what is wrong.
Оценка 0
Добавьте свой ответ
Chao bu guay будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 144
