Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597вопросов Показать все
MacBook Pro Mid 2012 15'
I wanted to take on a project with buying a MacBook Pro 15' Unibody Mid 2012. I wanted to make it the best possible of this model. What do you guys think?
I was thinking:
  • i7 (?)
  • 16 GB RAM
  • Dual Hard Drives (Both SSD's)
What do you guys think about that? Will this setup be any good, or should I just buy a new one that has the Touch Bar?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
This is probably my favorite MacBook Pro of all time.
Apple MacBook Pro "Core i7" 2.6 15" Mid-2012 Specs
Identifiers: Mid-2012 15" - MD104LL/A - MacBookPro9,1 - A1286 - 2556*
https://everymac.com/systems/apple/macbo...
Go with a 1 TB SSHD or a straight SSD to really give it a kick.
I try to keep one of these in stock for sale at all times.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
What do you think about a dual drive setup?
из
Why dual SSD's? I think a single one thats larger will give you more performance. I have the next one up a i7 2.7 GHz and I have a single 1 TB Samsung 850 EVO SSD. I promise you the SSD is not the limit here on this puppy!
из
I just picked one of these up a couple of weeks ago. I was fortunate to find an i7 2.7 ghz model (highest config). $350 on Craigslist. I DO have to replace the screen, unfortunately. It has the hi-res screen, and a couple of days after the purchase had a small line of pixels going down the screen. I mainly use it with an external monitor, but the screen replacement is cheap enough (buy a 2011 screen off of eBay, and modify the connector to make it fit the 2012). So far I am VERY happy with this computer. Upgraded the RAM to 16GB (fortunately, I already had this, pulled from another computer), put in a 250GB 860 EVO as my boot drive, and put a 1TB HDD in the optical bay. Geekbench scores for this $350 computer are ridiculous. My particular machine is scoring 13,400 multi-core. The ONLY thing I really miss is the retina screen from my 2013 13” retina. But, the matte “hi-res” screen on this computer is definitely not bad. Some people consider this model to be the best MacBook Pro of all time, as it is the last fully upgradeable model.
Оценка 2
Добавьте свой ответ
haakonem будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 156
