N64 Turns on but there is no video
So I was given a N64 to repair and was told that it would play sound but no video. However, when I brought the N64 home to check it out, there was no video or sound. The red light comes on. I have checked all of the cables and power supply with another working console, so those aren't the issue. I have also tested the game and jumper pack I am using on another console and those work as well. I have done my best to clean the cartridge slot and expansion slot. I have even gone as far as resoldering the pins of the cartridge connector, A/V port, and power port.
EDIT:
I'm not sure if this is important to point out, but while I don't have any video/audio, there is a change that happens on certain TV's when I turn the console on. I am using the RF switch for my N64 and when I turn the console on, the TV goes from just displaying static to a black screen. However, it still shows the "No Signal" message on the TV.
Это хороший вопрос?
2 Комментариев
Hi @legendarylee ,
Have you seen this?
No video- not cable or connections.
Also scroll down and take note of the last "answer" in the thread. Just so that you're aware of it before trying the 'solution' at all
из jayeff
@jayeff Thank you for your comment. Yes, I have seen that post and many of the other similar posts on here about this issue. I have tried the stepwise protocol twice and it didn't help my issue.
из Lee Weldon
