Полная разборка и инструкции по замене для оригинального iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s и iPhone 6s Plus.
36476вопросов Показать все
Possible to do recovery without installing baseband?
Hi Community,
I am wondering if its possible to customise firmware to remove the baseband installation process.
I currently have an iphone 7 which is just going to end up becoming a data recovery due to GOD knows what the last repair shop did. However, i can nearly install firmware up until the dreaded 80% install, -1 baseband error (using 3U with data being saved option ticked)
I have done all repairs around this error and cant invest anymore time on the project, but just wondered if this is at all possible??
Thoughts and advice?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
on 3u did you try unticking reserve baseband while flashing under the pro flash section
Был ли этот ответ полезен?
Оценка 2
5 Комментариев:
Yep. Still fails at that point
из
what about removing the baseband ic itself, the phone will boot without it
из
It boots to recovery mode, but I can still flash while keeping data. If I remove the baseband, won’t it still fail in the recovery process??
из
Did you ever got to solve this?
из
I hope he attempted exit recovery mode on 3utools becaused failed restore / update attempts keep a phone stuck in recovery mode.
из
Добавьте свой ответ
Jacob Harvey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 16
За всё время: 4,175
